This command resets the MSDP counters to zero.
peer all | Specifies all MSDP peers. |
remoteaddr | Specifies the IP address of the MSDP peer. |
system | Clears the global MSDP counters. |
vrname | Specifies the name of the virtual router to which this command applies. If a name is not specified, it is extracted from the current CLI context. |
N/A.
The clear msdp counters command clears the following MSDP counters:
The clear counters command will also clear all MSDP counters, but it clears the counters for all other applications too.
The following command clears the counters for an MSDP peer with the IP address 192.168.45.43:
clear msdp counters peer 192.168.45.43
The following command clears the all peer and global counters:
clear msdp counters
The following command clears all counters for a particular peer:
clear msdp counters peer 192.168.32.45
The following command clears the counters of all MSDP peers:
clear msdp counters peer all
The following command clears the global counters:
clear msdp counters system
This command was first available in ExtremeXOS 12.0.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the MSDP feature, see the Switch Engine v33.1.1 Licensing Guide document.
